Have Turbo, what else?
MeanDmax
Ya, it's Fubared
Apr 16, 2010
47
So I have a GT4094R, I was looking at the PPE install kit, but I think its a little expensive for what your getting. If I purchase a pedistal and than a down pipe, what else do I need, other than a t4 gasket. I see the ppe kit comes with another oil drain, it looks like the stock one with an extra sleeve welded into it to male it longer. Any advice?
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
you can buy my whole kit and the turbo and have a spare turbo :) then i can get my new s475 i have been wanting!
paint94979
Beer Nazi
Sep 18, 2006
11,715
If i was you i would buy the PPE kit... contact one of the vendors here Henry(ripmf666) can get you a much better price than what is on PPE's website. My PPE GT4094R kit fit flawlessly.
paint94979
Beer Nazi
Sep 18, 2006
11,715
oh and while you are at it... i'd buy the GT42 install kit. It gives you several more inches of clearance and in case you want to upgrade to say a GT42 or S400 in the future you can reuse everything minus the turbo:thumb:
ChevyDieselLLY
Whats A Budget???
Apr 1, 2008
2,684
MI, NC, now Hawaii
now what is some good info there. cuz everyone knows you always need a larger turbo
Righteyeblind
712
Fairbanks, AK
You can put together a cheaper kit then ppe. The rdl pedestal is taller the. Ppe so you don't need the spacer and it is tapped on the t4 flange instead of just drilled. Then I would stud the pedestal where th uppipes go on which also makes for much easier turbo changes. 10x1.5 studs. Oil line kit from fleece works well and the. You need a downpipe and an intake. The intake sucks to make fit and nobodys install kit comes with one. I used the 4" non crush intake tubing, it looks like dryer duct, until I made one out of piping. Hope this helps.
ripmf666
15,123
14
47
Wentzville Mo
So rdl ped around 500. Fleece oil return think it's 200 and someor 250. Down pipe yur looking at at 200 to 300. At the end it's easier getting the Ppe install kit. Tge little parts add up fast and once the truck is apart and the longer the more pissed you get about it trying to get what you needed to work. Not many make a one off down pipe for the 4094 and even if insole you the rdl ped with it being taller like the others are pointing out to do if you try and break down and call Ppe for a down pipe there's will not work for you at this point. Just ask Nick aka paint above he tried outing a intall kit togther part by part ended up weeks along and more money spent the the kit. But it's each his own. :hug:
