I'm still having a few tranny issues. Ever since the rebuild I will have days where there isn't a bad shift at all and sometimes it will get funky on the 2-1 downshift. Sometimes barely noticeable and sometimes it's WTF but then it's fine again.
I spoke with Mat and it appears via a scanner that the 2-1 will be in adaptive mode and then occasionally jump to fast learn and back again which would make sense why my trans acts perfect at times and then gets funky and clears up again. It was my understanding that fast learn could only be set via a proper scan/tune tool, so it swapping back and forth leads me to believe the scanner might see it incorrectly or my truck is possessed.
It could be the scanner is wrong (he mentioned something about his Tech 2), but it would explain the peculiar habits of my tranny. I would think if it was mechanical it would do it all the time (or at least more of the time).
Also wondering if my TCM could be messed up. The front end of my truck was damaged in the initial crash in December, not sure if that has anything to do with it as many of the front end pieces were removed/replaced. Maybe they unplugged it and left it open (don't know).
The TCM has never been messed with and the ECM has been running the OEM tune since last October. I hooked the predator to it to pull codes for Mike L when the tranny first went out and I tried hooking my V2 to it to get something other than the generic 0700 tranny code, but was unable to get it to connect with my new work laptop so I gave up.
Mat's working on it and I'm sure he'll take care of me, just thought I would ask if anyone else has seen this peculiar behavior? It figures it would have to be my truck/luck that would have a 1 in a million problem....
Thanks in advance.
Thanks in advance.
