Harland Sharp Roller Rocker Arms 6.6L Duramax Application: 01-12 GM 6.6L Duramax
ripmf666
15,123
14
47
Wentzville Mo
$1,800.00 shipped in the Continental US
Harland Sharp D-Force Roller Rocker Arms are manufactured in-house out of 2024 Billet Aluminum to ensure maximum strength and durability for your Duramax valvetrain. The D-Force roller rocker arms also feature a roller tip for superior friction reduction and increased performance. For use in racing applications, and with no required modifications, the D-Force roller rocker arms from Harland Sharp truly are the simplest way of maximizing your diesel engines valvetrain performance!
Features:
  • Made from 2024 billet aluminum
  • Roller tip for friction reduction
  • Installs in place of factory rocker arms
  • Sold as a complete set
Leadfoot
Needs Bigger Tires!
Dec 27, 2006
904
31
Western MA
www.matpa.org
Unless I'm blind or stupid (could be both), I don't see a "roller tip".
I see the fulcrum is roller, but the tip looks to be a hardened pad with a groove behind it for lubrication...?
ripmf666
15,123
14
47
Wentzville Mo
New pic added they had the wrong pics up. Also I will add the price back later when I find out what the price is 100%.
S Phinney
4,008
Quncy, Fl
Those won't be a problem. Only problem right now is that the are not available for the lb7. There is a clearance issue associated with the return lines. All other models are good to go.
Sent from my DROID RAZR using Tapatalk
MarkBroviak
DMax Junkie
2,132
460
Danville Indiana
No valve adjustment... Did I miss something here? These are alittle pricy, was looking to test them on the engine dyno but not really sure it would be worth it yet and I don't have that much coin laying around for a maybe increase in power. Look good but needs to have a roller fulcrum for the price.
codyn
412
urbana ohio
The reason for the no valve adjustment in the photo was ratio was not selected yet. There will be a power increase but it will depends on other engine mods are done . On a stock lly duramax we saw a 15rwhp on the dyno from just the rocker swap. Roller fulcrum is not needed on low rpm motors.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
What ratio are they? How are you involed in this Cody?
What is the price Henry ?
codyn
412
urbana ohio
On the stock lly they are stock ratio Exhaust 1.69:1, Intake 1.36:1. I did testing for the past year and half or so and did the dyno testing on the stock truck with stock ratio rockers and the built motor testing with the ratio set of rockers.
Colt
Jul 23, 2010
523
HP costs are not feasable for me to pay that for 15 HP. Nice stuff but that's for money crowd who race or want it all I guess. No offense but after labor 2 HP per hole ain't in it.
