Hey guys, I just got the truck back together after doing HGs and injectors. Truck started fine for the first few test idles, put it through its first WOT tests last night, ran like a dream.
Started the truck this morning no problem, went to work and it started fine again at the end of the day. Drove it home and went to start it back up about 30 minutes later and it didn't want to start. I cranked it for about 8-10 seconds and no fire. I then left the key on to let the lift pump run and it cranked right up. Did the same thing after experimenting all night.
Things to note here. The problem only seems to happen when the engine is hot. Letting the lift pump run allows it to fire right up. The problem surfaced only after I took it out for a few WOT tests, before that it cranked just fine multiple times while checking for leaks right after it was back together. I dont think it's injectors as they are brand new from a trusted company. I'm also getting a p0370 code. Primer on top of fuel filter is rock hard before trying to start.
I know you guys are going to ask for logs, but unfortunately I have no way to check those at the moment. I'm just hoping you guys can point me in the directionof possibilities.
Fuel line collapse when the engine gets hot? Air getting in the system? Bad cp3? (Hope not). Help! Thanks!
