H2 Rims on Stock 2500HD ???
P0sTaL_2500HD
New2Dmax
Aug 26, 2009
13
Don't you wish...
hey everyone, just looking on getting a set of H2 rims for my stock height 2002 Chevy Silverado 2500HD. I know the rims are 9" wide and and the size is 17". My question is what size of a tire can i put on the rim and still have no issues with the stock height.. I was told that i can run a 275/65/17 on the truck with the H2 rims. Id like to get some inside on what should i do.. Im going to be getting the BFG All-Terrain T/A® KO as the tires for the rims..
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
i used to run 315/70/17's they did not rub at all. then i put on 265/70's for the mileage and improved handling while towing.
1,842
You guys must have Fords if 285's dont rub without raising the Tbars up some. :rofl: 285s look good but they'll rub something fierce at stock height.
Noreaster
2,910
42
Cape Cod,MA
Thought they were 8.5" wide
Im running 285/70/17 Nittos at stock height
Buying 305/65/17 Mickeys this week, see if I have to raise it alittle
Diesel Pilot
Hat? Suitcase? 50 BMG?
Aug 9, 2006
1,424
47
Pickerington, OH
I'm also in the market for tires for H2's for winter.
I currently have 285/60/18's and they only rub slightly when backing up and the front end is slammed.
I really want 275/70/17 but nobody makes them higher than load range C.
I'd go 265/70/17 but it seems like it's hit or miss if they look stupid or not.
Here's what I've come up with.
265/70 would be the same height as my current tires but much skinnier. (pro = they fit fine, con = they're too skinny for rims)
285/70 would be the same width but 1.3" taller. (pro = look great/ con= don't want to change stance for huge tires)
275/70 would be perfect but worried about load range C, even though I don't tow anything. (pro = size is perfect, con = load range C could cause issues down the road)
dmaxfireman
Apr 8, 2007
2,329
CT
my next set of tires for my h2's will probobly be a set of 305 65 17 load range e bfg at
33/12.5 they will fit.
DragginDMAX
NObama
Oct 6, 2009
I had 285s on mine when it was stock with my t-bars cranked and trimmed the lower bumper valence a little bit. worked great and never rubbed after that.
Mr. Goodtime
Always Breaking Parts
Sep 15, 2009
55
Waverly, Oh
I have the 305/65/17's on both my trucks and with the tbars cranked on my 01 no rub but my 07 I had to trim a little but they only rub under hard turning.
Noreaster
2,910
42
Cape Cod,MA
I ordered them this morning
I wouldn't think they would rub on your truck with the green keys, Im at stock or close to height & I don't have a valance right now
