Who has installed one of these h2 shafts in place of the factory axle disconnect and stub axle? The original outer axle has a snap ring just inside the outer case that holds it in place. The h2 axle has a snap ring all the way at the end on the splines. Do i have to split the main diff case and put the snap ring on after the the outer case and new axle are all slid on?
