Does anyone know what needs to be done to swap in a GT47 in place of a S483?
cafryer New member May 5, 2011 1,074 0 0 Utah Sep 18, 2011 #1 Does anyone know what needs to be done to swap in a GT47 in place of a S483?
emiller3 He's Back Feb 21, 2009 3,586 0 36 42 lake charles,LA. Sep 18, 2011 #2 I would imagine both hot and cold pipes would need to be modified.
Burn Down Hotrodder Sep 14, 2008 7,092 28 48 Boise Idaho Sep 18, 2011 #3 Depends on the ex housings t-4 or t-6, I think the rest could be massaged to work.
TrentNell Finally underway !!!!! Jul 7, 2008 7,543 0 0 44 slc tuah Sep 18, 2011 #4 how is your turbo mounted ? if its by the exhaust flange a charge pipe is all that should need to be modified , if its mounted by the drain flange it could be both , maybe the bracket also depending on the positioning of the turbo.
cafryer New member May 5, 2011 1,074 0 0 Utah Sep 18, 2011 #6 I will try and figure out how to load a pic.
cafryer New member May 5, 2011 1,074 0 0 Utah Sep 18, 2011 #7 This one is the best one i got. Attachments IMG_0730[1].jpg 741.1 KB · Views: 127 Last edited: Sep 18, 2011
Burn Down Hotrodder Sep 14, 2008 7,092 28 48 Boise Idaho Sep 18, 2011 #8 Do you have the garrett picked out?
delong_1 << my work Dec 5, 2008 1,282 0 0 38 Arvada, CO Sep 18, 2011 #9 I swapped my s480 out for a gt 47 last year and didnt have to change anything
cafryer New member May 5, 2011 1,074 0 0 Utah Sep 18, 2011 #10 That would be awsome and how did you like the swap?
cafryer New member May 5, 2011 1,074 0 0 Utah Sep 18, 2011 #11 Burn Down said: Do you have the garrett picked out? Click to expand... Not 100%
kivetts04dmax New member May 20, 2010 742 0 0 Boonville, MO/Pendleton, CA Sep 19, 2011 #12 those look awesome!!
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Sep 19, 2011 #13 cafryer said: This one is the best one i got. Click to expand... How old is this pic? I thought I read in your Sig your running twin modded cp3's.
cafryer New member May 5, 2011 1,074 0 0 Utah Sep 19, 2011 #14 It was taken before the pumps and 60% injectors also that is my old 474. Lots of changes since then i will load up some updated ones soon.
blk smoke lb7 <-----Lots of green $ Nov 8, 2010 5,694 0 36 57 belvidere,ill Sep 19, 2011 #15 Lookin good under the hood :thumb:
cafryer New member May 5, 2011 1,074 0 0 Utah Sep 20, 2011 #17 Going by these pics does it look like i will have to change the hot pipe?
770JOHNNYW New member Sep 16, 2009 791 0 0 Gainesville ,Ga Sep 20, 2011 #18 the s483 have a 4'' exhaust housing doesnt it? the 47 will be 5''.
770JOHNNYW New member Sep 16, 2009 791 0 0 Gainesville ,Ga Sep 20, 2011 #20 cafryer said: No i think it is 5". Click to expand... gotcha wasnt sure
