LB7: Grey/blueish smoke while cruising
KEVINL
1,431
Phoenix, AZ
My trucks has started smoking grey/blueish while cruising and under light acceleration. It does not smoke at idle oil looks good any ideas?
Injectors?
KEVINL
1,431
Phoenix, AZ
No, When I start it there is a puff of black smoke
idle is clear
It is when I am lightly on the throttle or cruising is when it smokes grey/blueish it turns black with slightly more throttle
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
You can check the balancing rates and see where they are at to start with. No ther fuel codes? When I had my 02 when the injectors went bad a week before hand I kept getting a low rail code whenever I got after it and they started getting loud. It smoked like your describing but I had fuel in my oil.
