Gray smoke
02duramax
162
Yreka Ca
I have been a reader of this forum for some time and i have really enjoyed it.
i have a issue with the smoke coming out of my exhaust. Let me tell u i got a 02 stock LB7 with a PPE boost stick and 4 " turbo back, Aem big brute air intake.. K my exhaust smoke was normal (like no smoke at all) and now i got some gray smoke flowing only when i am on the gas. If anyone could advise me to what is going on would be appreciated.
thanks
paint94979
Beer Nazi
Sep 18, 2006
11,715
thanks
i would consider that normal? Mine does this as well.
02duramax
162
Yreka Ca
Just wanted to update as to this so called gray smoke. Took it to dealer to have a diagnostic done (tech 2 info).. They called me @ lunch today to give news as per inspection. They said i had 2 leaking head gaskets and 8 bad injectors. I have only had this truck for 3 months, when i bought it i got a WSA warranty on it. The dealer said i had a full lifetime warranty on my motor.. I had the dealership call the warranty place and go about a claim for headgasket and see about the injectors also.. NOPE.. my warranty does not cover gaskets or seals nor the injectors. So i am then told by the dealership that i am over the 7 yr/200,000 mile warranty by 30 days, as i have a 02 duramax.. But hell no it isnt, they go by the manufactured day it was built, which was 12-18-2001. i am so F___king pissed, here is a picture of the print out the dealership gave me. i asked for balance rates, but they said they didnt have to go that far to tell all 8 were bad. anyone else have this issue.
LBZrcks
Jun 2, 2007
5,297
12
SoCal
Injectors are a common problem on LB7's but I thought they go buy the date the truck was sold or put into service rather than the build dates
dmax lb7
EFI Ignorant
Feb 21, 2008
79
Rohnert Park Nor-Cal
I thought they were going off of the date the truck was sold or put into service, not the date it was manufactured. With GM's money problems they are looking for any reason to deny a claim.
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
Yep if you read this TSB it is when the truck was placed into service.
Have you had the guys run the vin to see when it was placed in service?
http://www.duramaxdiesels.com/forum/showthread.php?t=4725&highlight=injector
Huntinducks82
Apr 21, 2008
422
42
Centerville MD
How can all eight injectors be bad and but the head gaskets are blown and you still be able to drive the truck up the road. I believe i would let someone else take a look at it and get the facts straight about the 7 year warrenty deal. Thats BS. Sorry man hope you get you truck fixed let us know what you find out.
02duramax
162
Yreka Ca
truck idles fine, runs fine, just smokes white alot when i accelerate on the pedal. They said i had 2 leaky head gaskets and all 8 injectors were bad. Now tell me why is my truck idiling and running fine? yeah they went by the day it was put in service, i worded it wrong, my bad. Dammit, i missed all this repair by 30 days.. wtf :mad:
exact words from dealership print out:::::
DTC p1094 low fuel rail pressure during power enrichment set road tested vehicle had white smoke under acceleration. check d max fuel pressure was
at 134 mpa spec is 160 mpa injector returning to much fuel and cooling system is building pressure and blowing coolant of overflow relief.
NWTDIESEL
On a Time Out
May 8, 2008
1,405
ATS Extreme trans
What are you going to do? I counted the days down on my truck for when the warranty would expire. I took it in right before it expired and had them done. Someone hear can surely help you.......i know there are some techs that can still get you in under warranty.
Jun 28, 2007
3,259
NE Pa
I'm not sure about the extended warenty but with the regualr one it starts when the first owner takes delivery....not when it was built
02duramax
162
Yreka Ca
It is not using water, runs good, idles good, only smokes when i accelerate now. check dip stick smell, burnt oil only smell.
02duramax
162
Yreka Ca
where would these tech's be? around colorado?
