LBZ: Gotta fuel pressure gauge question
Snichols243
Aug 15, 2012
19
Columbia Mo
i recently put gauges in my truck boost pyro and fuel pressure the boost and pyro work good, but the fuel pressure..... i know people say you wont read anything at all if you dont have a lift pump... i have a raptor lift pump (came on the truck). when i had the wires disconnected from the sending unit the gauge read max pressure 30psi but after my adapter came in and i hooked the sending unit up, the guage doesnt read anything, n i can hear the raptor running. any one have any ideas ? could the raptor not be working right or the sending unit for the gauge not be working??
Thanks
rgullett83
1,607
Illinois
What brand of gauges? Is the primer hard with the lift pump running, if so then the pump is working and you have fuel pressure. Double check all your wiring for the fuel psi gauge to make sure it's wired correctly.
Sent from my GT-I9300 using Tapatalk 2
rgullett83
1,607
Illinois
I don't want to be a Debbie downer, but my experience with gloshift gauges has not been good, they are cheap, but in my opinion very low quality.
Snichols243
Aug 15, 2012
19
Columbia Mo
Ya I kinda got that feeling when I was installing them , they look soo good though. Lol. But this morning I turned the key could hear the pump running and I could push on the primer but idk what its like without the pump on
I mounted the sending unit in the bleeder port on top or the fuel filter
bluecollar
351
ia
My brother got 3 sending units from them never could get it to work. Never a problem with boost and egt tho.
rgullett83
1,607
Illinois
Do you know anyone that has a vacuum/pressure gauge to hook onto the factory test port, to check psi with?
rgullett83
1,607
Illinois
Also you could turn the key on so the gauges are powered up, and have someone watch it while you pump the primer to see if it builds pressure
13,711
772
That's what I was about to suggest. If you pump the primer on top of the fuel filter, it will build a lot of pressure. I can max out my 15 psi gauge doing that. It should hold long enough for you to walk around to the gauge.
Snichols243
Aug 15, 2012
19
Columbia Mo
Well this morning I pumped it once, not knowing if I was going to mess something up ,but when I closed the hood and got back to the truck the gauge still read 0 so tonight ill have someone get in the truck and see if pumping the primer makes the gauge change , and i think i may have access to a gauge to read the pressure.
So my two problems prolly one gauge/sending unit isn't working. Or two the Esprit isn't working right and the truck is running like it does without a lift pump.
Idk if this have anything to do with anything but my whole reason for gauges is that when I'm dam near at full throttle the truck throws a low fuel rail pressure code , the truck came with a tune in the computer guess it used to have efi live but the dsp 5 has been cut out.
Thanks for the help guys. I'll have to do some playin tonight see what I can figure out.
Duraskank
Flippin Rides
Nov 30, 2011
27
It did have a dsp5 setup from rob in it and a cts insight for gauges. When I sold it the new owner had it tuned again at scheids and put the lift pump on it I assume cause I never did. He tried to tell me it was never tuned in the first place and whined around about the cost to tune it again cause he didn't have my v2. So at least you know a little about it now :)
He talked about building the tranny and a bunch of other bs but I saw it on a car lot in MO, where you prob found it lol.
Can't believe he basically sold everything off it that I did....smh.
Snichols243
Aug 15, 2012
19
Columbia Mo
So you used to own my truck ? Small world. Haha ya I'm trying to get the fuel pressure deal figured out then I wanna try and tune it again. Mainly because idk what it has in it now , and this is the first dmax I have ever been around. I also got an old 12v cummins
Duraskank
Flippin Rides
Nov 30, 2011
27
Yeah I bought it in Guthrie, Oklahoma from a dealership my buddy owns. Here's what it looked like when I got it:
And here's how I sold it:
jnieberlein
Secret Squirrel Diesel
Aug 17, 2009
689
West By God
Sounds like the FPRV is popping off at wide open throttle, for the original owner was the FPRV ever shimmed? your lift pump nor your gauge is going to help with this problem. need to check if you are losing rail pressure w/ tech 2 or a EFI
Snichols243
Aug 15, 2012
19
Columbia Mo
dang the guy i bought it from stripped it didnt he! it was a dam good lookin truck when you sold it! but the guy that had it before me says it has a shim kit, and i have one sitting in my console but sence he told me there is already one in it i dont want to break it open to see, n i dont know if i should believe what the other guy has to say.
greif03lb7
cc/lb and lovin it
Dec 9, 2012
96
Granger, Ia
Plus if he did shim it he probably only used two shims not three. Get efi and tune it out so it cant throw that code and limp. Mine would still throw the low rail psi at wot after I shimmed it. You can do the bottle test also.
