well i had a thread about how i wasnt sure if i had a bad head gasket or not, well now i know i dont,
i finally got down to the injectors on sunday, lets just say im not pleased at all,
heres the back ground on the truck, i bought it in august of 09 when i bought it the first thing i asked was were the injectors changed yet, he said yeah they were just done, so i assumed GM did them since it was still under warrenty, well after drivin down to Schied, i wanted to check all my fluids before i came back home, so i checked oil it was fine, went to check the coolant and after sittin all night it overflowed the tank when i opened it b/c of all the pressure so i was kinda worried but figured maybe it was just the hours of bein on the road the previous day, less then a month after i got it i noticed it was smokin quiet a bit at an idle so i emailed the guy i got it from to ask what shop did the injectors b/c they are either idiots or put in junk parts which still makes them idiots, he told me ohhh i got them off ebay and my dad put them in his dad is a wanna be mechanic....fast forward to december, its smokin so bad at an idle its embarrasing at stop lights, and the low coolant light comes on so i add half a gallon or so adn its fine for awhile then it pops back on,
so i finally ordered my stuff a couple weeks ago and i started tearin into it on thursday, well i found so many wires not connected right, bolts not tight, and the rocker cover (lower valve cover) didnt have a gasket it was siliconed as well, all the rocker cover bolts were rounded out they put them in so tight, i had to use an air grinder and small cutting wheel to cut 2 of them out, and of course they were the hardest to get to, 1 on the pass side lower valve cover all the way in the back, and 1 on the upper cover on the driver side under my steering stuff,
but i got them out, found 2 inj return line screws that werer rounded out luckily they dont need to be too tight so vise grips got them off, so it was time to pop injectors out, i started on the pass side, the very first one i pulled was double copper ringed, the second one, pulled a cup, the 3rd and 4th had 1 copper ring so i think i still got one stuck in there, move to the driver side all 4 pulled cups w/ them, took them up to my buddies b/c i didnt know how the cups were supposed to sit and he said they were all double coppered b/c the cup was sitting really low on them all
im hopin i can get some of the cups off and save the injectors, i have his 8 stockers and my 8, out of 16, 6 have cups on them
