Got a 68mm Stg2r on the way from Evan!
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
Finally got the turbo I've been wanting for a while now. Can't wait for it to get here. Thanks Evan!
Houser04lly
367
Fort Myers, Fl
How much are you plannimg on pushing it .. I am planning on getting it also but wasnt sure if I should get bigger nozzles to save the motor a little while its apart for studs
Jan 28, 2015
961
Ohio
You will be fine at 625. Mine would drain the rail until a put a race plug in it. I plan on sending my cp3 to mark to get modded since it's pretty cheap.
Jan 28, 2015
961
Ohio
Also I'd consider 60 overs if you don't plan to build the motor. Chris said his was pretty smokey with 100 overs on his lmm iirc. Same turbo
N2BRK
2,041
352
I'm where you want to be and I'm on 40 overs. It's still a bit smokey until she lights; I can only imagine how smokey 100 overs must be
