So my truck is tuned pretty conservatively and I don't ever really beat on it and I don't really crank it up I'm probably around 80 hp above stock. I do tow heavy though. I'm under 40k miles.
I've developed a funny 2-3 upshift. It seems as though 2nd gear docent disengage before 3rd grabs. There is no slippage and every other gear is perfect. Neither 2nd or 3rd gear slips. Problem seems worse when the torque converter is locked. Also it seems to be less noticeable the more throttle I'm into during when the shift occurs. Other then that the trany works like clock work. Ive never limped this tranny.
I did have a rear speed sensor wiring go bad on my witch I repaired and reset the codes.
Tranny fluid was a bit dark. Dropped pan fluid and fresh spin on and 1.5 gallons of fresh transsynd.
I have no codes I'm thinking of resting my taps with efi live for 2-3 upshift maybe the speed sensor wiring going bad confused the tranny?
Any thoughts or stuff to check?????
Thanx as always.
Thanx as always.
