Info: Good Recent Diesel Engine Article
ZeroGravity58
1,401
51
Maryland
good reading. In the article banks says lb7/lly pistons are good to 700HP and 5,000 RPM where the LBZ pistons are good to 550-600 HP and no additional RPM. We all thought it was HP cracking them. Maybe it is the added RPM of some tunes that we use....It also says the LBZ pistons are made in Japan:rolleyes: go figure they would crack :rofl:
stacks04
792
Terryville,Ct
i doubt that many of the failures are rpm related. i see alot that are done with regular tuners, off the shelf stuff that dont alter the rpm.
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
Heat is way worse the rpm, on the pistons.
Good read. Brayden is on top of things. BTW I got the chargers out today.
