Good Passes at the Track
Harbin_22
3,858
Southern Indiana
[YOUTUBE]Tr2HCYKuyk8[/YOUTUBE]
Made some good passes this weekend at the local diesel event. Stayed around 6.7x's most of the day with my best 60' only in the 1.6x range. Best pass was this one with a [email protected]. Best MPH to date. Very happy with the truck other than I am having the infamous can't hold it at the line. Got some new lines and all the fluid to change the PS and brake fluids to see if that helps. Can't thank Mark and Evan enough for all their help and awesome parts along the way.
CaptPhil
1,012
Delaware
Running good for sure. Need to make some full quarter passes and see what it will do.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Damn Kyle awesome!!! Sorry the time frame couldn't work to meet up with you guys when you were in AZ. Truck is running great!!
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
Natrona Heights PA
Never have had any abs codes or any speed sensor codes. Wheel bearings are tight too.
My ABS light came on after a year of the same issue and the brakes worked great! 20 psi with not problem. Unfortunately the light shut off again before I could read it.
Your truck is setup really well. Awesome mph on that pass!
