Idk I just ran across it and thought the crank part was intresting. It listed all the dimensions for bore and stroke does it calculate to the compression ratio they say? I don't remember how to calculate compression.
Sent from my C811 4G using Tapatalk
It's a longish process process, easiest to just google a calculator. Summit has one as do others. I like math though, and for those who like numbers as well, here's the paper way to go about it. If it seems hard or confusing just lookup common core math:thumb:
The bore and stroke for the Duramax has never changed, the piston design has which is why the compression is lower later. The reason for a compression drop I assume is emissions based. Cooler combustion produces less NOX. Most OEM's did the same thing.
Displacement = (Bore/2)^2*3.14*Stroke*16.387
Head Gasket space = (Bore/2)^2*3.14*Gasket thickness x 16.387
Deck Height space = (Bore/2)^2*3.14*Deck Height x 16.387
Compressed Volume = Head Gasket space + Deck Height space + Piston Bowl volume + Cylinder head volume
Uncompressed Volume = Compressed Volume + Displacement
Compression Ratio = Uncompressed volume/Compressed volume
So for the Duramax. (slightly rounded)
Displacement: (4.06/2)^2*3.14*3.90*16.387= 827cc
Head Gasket Space: (4.06/2)^2*3.14*0.042*16.387= 9cc
Deck Height Space: (4.06/2)^2*3.14*0.014*16.387= 3cc
Compressed Volume: 9+3+42+0= 54cc
Uncompressed Volume: 54+827= 881cc
Compression Ratio: 881/54= 16.3
The headgasket thickness and deck height are middle numbers for grade C thickness. The piston volume is a spec from Mahle for their aftermarket forged pistons which have a 16.5:1 ratio. I rounded enough numbers just to make things quicker and easier on the eyes. The LB7/LLY had a 17.5:1 compression ratio. Using the numbers above that puts the piston bowl volume at around 38cc. 827+50= 877cc. 877/50=17.5
I also don't get why they said the LML is just an updated LMM, but then they state drastic changes were made. The latter is true. I guess its what you get when you have an editor writing a story without personal knowledge and just going off what was told to them (pretty obvious throughout the article). Its also obvious the 15.8:1 was a typo because there was no mention of compression ratio changes anywhere and its wrong anyways.
