First off.. this is my first post.. Hi all.
I'm going to look at a 2002 LB7? Duramax. It's a crew cab, 86k miles, and has a pretty big lift on it.
My biggest concern as you may have guess is the injector issue. I read up about it on here alot but i'm still a little unclear. I called my local chevy dealer and had them run the vin. The injectors were replaced in 04 with 30somethingK miles, and the glow plugs in 06. It's my understanding that the injector failure may not be the injectors at all rather what controls them. Something about too high of voltage or not enough fuel pressure to them, or both. My question is, if the injectors were swapped out already, what are the chances the problem is solved?
Secondly, like i said it has a lift and therefor larger tires. How does the Allison in the 02's handle not so much the extra wieght to move them, more the RPM changes and shifting more due to the actual size? I don't know how big the tires are yet, but they look like 37's.
Any help would be great as I really want this truck, and i can afford it, but the huge repair bills might drown me.
