Hey mike if you happen to catch this thread ive got a question for you. Sometimes when i go to put my truck in park it does not go in all the way so i have to drop it all the way into first and go all the way up, then it usually will go to park. It seems to be getting worse, i pulled the pan to do a internal filter change on saturday and did a little bit of looking around. I didnt really come up with anything except maybe my detent spring is worn or maybe my cable stretched?? idk but i took the selector arm of the nsbu switch to check for wear and it was pretty tight. Do you think that manual valve could be messed up or the parking pawl spring is weak? Any suggestions would be appreciated, thanks!!:thumb:
