GM pickups to adopt active grille louvers for fuel economy?
Poltergeist
Ghost in the Machine
Aug 1, 2006
29,563
Ontario, Calif.
www.poltergeist.us
General Motors' full-size pickup trucks may be next in line to get thermostatically controlled louvers behind the grille to improve aerodynamics. SRG Global, which produces a variety of components for numerous manufacturers, is developing just such a system for GM's trucks. Similar systems will debut later this year on the Chevrolet Cruze and later on the new Ford Focus.
One of the biggest sources of aerodynamic drag and turbulence comes from the air flowing through a vehicle's engine compartment. Closing off the grille to limit this airflow can drastically reduce this issue, however, the engine still needs air for cooling – especially at lower speeds. At higher speeds, the increased air velocity means less open area is required for adequate cooling.
Thermostatically controlled slats monitor coolant temperatures and then open or close as needed, giving the best of both worlds at the expense of a bit of added cost and complexity. That said, SRG's new designs will integrate the slats into the grille structure reducing the cost of the system and making assembly simpler. Theoretically, such technology could also be used to improve cold-weather warm-ups by keeping the grille's slats closed.
9,905
151
Nothing like taking a concept that evolved and was used 40 some years ago and calling it new!!:rolleyes:
minisub
6-5/6-6;Whatever It Takes
Sep 11, 2006
474
Cleveland, OH
When I first got my LBZ I talked with Fingers a bunch about making a custom grill insert that had thermostatically controlled slats that were the same profile as the VVT vanes. Thought it would be a neat look, create an object of discussion and obviate the need for a winter front....Never thought this was a new idea as I have seen semis with slat grills since I was a kid....
Fingers
Village Idiot
1,719
104
White Oak, PA
I mocked it up on the bench at one time. Always wanted to put them just in front of the radiator stack. But the grill would be cool too.
05' Ditry Duramax
May 3, 2008
1,294
42
Port Orchard Washington
I wounder what kind of motor they would use to control it? I see some type of electrical /piston driven, slider type setup that would stop working at some point and then the truck would overheat and blah blah blah.....
I feel they are "trying too hard" nowdays. I don't want these trucks to go away but it seems that the EPA and CARB and all those other BS "associations" are trying to take the fun out of driving and owning a vehicle. I'm gonna sell everything and drive a 70's muscle car. All this new shit isn't worth it anymore. I don't even want to own a vehicle newer than 06'. Sorry for the rant but it get's to me.
02bigstrokin
Sep 9, 2008
882
sounds to me like its just something else to break. if they were so damn worried about fuel mileage why dont they take the bullcrap in the exhaust out.. like the dpf and cat. that would make a lot bigger difference then some louvers on the grill.:rolleyes:
Darius6t9
I'm the Floater. Lurking.
Aug 23, 2008
574
Rusk, Tx. Again
I've actually thought about making one of these myself. For warming up in the cols. Wouldn't have to worry about putting on and taking off the winter cover. And you could make it to work like an exhaust brake. It opens up or shuts off when the engine comes up to temp. I would think they would use a linear actuator for the motor. Make it work sorta like the old style blinds that had the rod in the middle to adjust the angle the slats were at. But have it to the side.
Fingers
Village Idiot
1,719
104
White Oak, PA
Doesn't need all the fancy electronics. Just a thermostat that reacts to the coolant temp coming out of the radiator.
Engine would warm up faster, yet not overheat.
