I just stuffed the diode in with the fuse pin...
This is the 3rd GM I've worked up like that, last truck I put 80k mi on with the all in diode
This truck I've had like this for 4 years and 50k mi..
All w/HID ballasts hooked up to the factory harness and plugs, never once had an issue of any kind with this
Costs $3 per application and 10min of time (once I made the trip to rat shack)
I used the diode method on my 03, 05 and 08 and I haven't had any problems. I used larger diodes on my 08 due to them getting too hot but I have had great luck with them.
Now you're complicating it for the electrically challenged, if it was 3 phase I understand it 'cus electricity is you're friend, now which number would be a larger diode..
Some people would rather pay a bit more for plug and play and retard proof installation.Fleece acts like this is something revolutionary...
Reinvented the wheel and charge 50x more.
Been done since The Place and works just fine.
I just like clean and don't want all the extra diodes and wiring. Pulling the fuse box cover to do it underneath is a pia.
Sent from my D5803 using Tapatalk
