Iv noticed now its getting colder out, I should be seeing my glowplug light on a little longer. I have no glowplug codes or a p0670 code. Checked with tech2 to verify. Its been 40 the past 2 days I looked at the tune its set to be on for 10sec at that temp. If you aren't looking for the light, you won't see it. Still starts fine for now. But it gets around 0*F in the winter here. Can the glowplug controller still be bad with no code? I also checked maxi fuse its good.
