Glow plugs
MadMaxx61
Devilmaxx
Oct 13, 2008
5,458
Windsor, Ont, Canada
Ok so its that time I need to change glow plug #4 I tested its done.
So what brand should I buy?
Should I change all 8 or just the one?
Whats a good price?
The ACDELCO ones around here I can get for $38.00 CAN each
But on RockAuto ( have to cross border to get them add $15 CAN )
BOSCH Part # 80044 at $23.97 +$2.05(shipping) USD each (total 25.84 )
ACDELCO Part # 61G {#97364968} at $19.51+$5.46(shipping) USD each (total $24.97)
If I should buy the Bosch I may call around town if I should only replace the one.
I did a search did not really find much on here about glow plugs most of the threads are about the controllers.
RockAuto also has STANDARD MOTOR PRODUCTS ones and NKG ones but I am not sure about them.
Thanks guys.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Stay with genuine ac delco/beru. Don't cheap out on them, I made that mistake and ended up returning all 8 and just replacing the 2 that actually needed replacing. Plus I bought 2 extras just in case.
I would replace them as they fail considering it is not a hard job to do anyways.
Dozerboy
4,892
470
TX of course
I was getting BERU's for $16 off ebay for a few years. If you plan on keeping your truck buy a set because they are normally cheaper and just due them one at a time. I have had 1 bad every year or 2 since my truck was 4 years old so I see no reason to do them all. But you might take them all out if rust is a concern and put some anti-seiz on them.
1pieceatatime
179
Schuyler NY
Just replace all 8. Or At least pull all 8 now while your in there for 2, never seize the ones you don't replace and reinstall. The ones you don't touch now are only going to rot more with each salty winter you go through, increasing the chances of one breaking off in the future.
9,903
149
I got Bosch or AC Delco can't remember which from Injectors direct. I think shipped all 8 were around $20. Change them all. And never seize them. Better than having a tip fall off later on.
Sent from my C6906 using Tapatalk
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
35
Goodyear, AZ
I just got Bosch at the dealer since that's what the truck came with factory. Around $35 each bit I only had 2 bad ones.
DieselmafiaLLY
Keep Calm and Go Crazy
Apr 6, 2013
1,102
Ontario, Canada
You guys have any tips or tricks to remove em. Ive heard alot of stories of them breaking when you try to remove em
Sent from my SAMSUNG-SGH-I537 using Tapatalk
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
glow plugs??? we don't need no stinkin' glow plugs!! :roflmao::D
I only have a couple that work on mine, no cold start worries in Texas! :thumb:
