LB7: Glow plug relay melted
poweredmotives
Nov 15, 2010
74
Colorado Springs
So I drove my truck to work yesterday with no problems at all and came out after work and it was totally dead. Ran back in and got my meter and checked the batteries and both were at .15V. I thought my meter was acting up so i got a coworkers and checked with the same result. Got a skidsteer to jump the truck with. Hooked up the cables to the skid first and went to put the cables on the truck and the negative terminal was arcing like crazy without the positive hooked up. Checked to make sure i had them on the skidsteer correctly and I did. Checked pass side battery and it was shorted internally, tried drivers side and it was also shorted. Very odd since i drove it to work and had no issues. Got new batteries today and put them in.
almost immediately the glow plug relay started melting and burning so i unhooked the batteries. unhooked the battery cable on the relay and hooked the batteries back up and everything is fine.
Any ideas on what happened? Relay killed the batteries or weird coincidence? Also with assuming the relay drained the batteries Would something be in place to shut the glow plugs themselves off or were they on until the batteries dead? Wondering if I should pull them out or not worry about it.
For those wondering, Yes skidsteer loaders are 12V not 24V.
5,911
glow plug/air intake heater relay went bad. when mine went, it back fed power to my fuse block and kept the truck running. replace it or disconnect it and you will be good to go
5,911
depends on how the relay fried but sounds like it was engeryzing the glow plugs till the batteries died
the freeze
Feb 23, 2010
Car quest priced my the whole fed emissions controller( black box studs and 2 relays if I remember) for like $90
I found a ford relay with some digging on the web that's rated at like 10 amps less for like $12. I bought o e and threw it in the glove box for spare in case.
I can get u the part number if u want but I remember thinking the male spades on it were a hair shorted on one terminal.
