I think I'm havin a glow plug issue won't start when it's cold how do I check to c if the plugs are lighting? It has the rail connecting all of em together I Obo there kno to go bad so any help is good thanks
there should be codes for the plugs if they are shorted, or if the glow plug module is not firing. If you want to manually check each plug you can remove the small wire going to each plug and take an ohm meter to each. Touch on end of the lead to the threaded part of the plug and the other end to the block and it should be around .8ohms if it's much higher than that it's likely shorted and bad.
good info right here, i had the same thing as OP and i did end up having two bad glowplugs and i still never got a code, are some newer models equipped with better GP controllers that throw codes easier?
01-04 federal trucks use a basic glow plug system with 1 relay that sends power to the #8 glow plug, a metal rail connects the drivers side glow plugs together, a wire runs from #2 to the #1 glow plug, and another rail connects the passenger side glow plugs together. The ECM only looks for basic resistance in the glow plug circuit, so if 1 works it will not code. Cali emission LB7's used a controller that would code if 1 glow plug failed(but it didn't always tell you which one), the LLY uses a controller to run the rapid heat plugs, and the LBZ/LMM use a controller wired in on the can bus I believe to run the glow plugs as well as coding for individual glow plug failures(tells you which one has failed).
Lb7's have a buss bar that connects all 4 glow plugs together and has only one hot wire going to each bank. Unless it is a cali lb7 then it will have an individual wire on each plug.
Also something to look out for is that lb7 and lly glow plugs physically look the same but are not interchangeable so make sure you get lb7 specific plugs and not lb7/lly plugs like some companies sell. Been down that road.
I would assume you could still remove the buss bar and perform the same resistance check? I have only messed with LLY's and LMM's so thanks for enlightening me there.
i'd get in to much trouble walking around with a hot poker!!! probably end up costing me half my shit if you catch my drift :rofl:
are they glow plugs a pwm signal? or just a straight relay setup? The gpm seems really large to be a simple relay setup, but I can't see the need for a PWM setup.
Lly's also tells you which individual plug has failed.
