Getting mixed replies from gm.
Henry95
283
Do I have 2 oil pressure sensors?
2005 gmc Dmax
Huffy67
Dec 26, 2014
270
Arkansas
As far as I know you only have one oil pressure sending unit on the driver side, lower part of the engine.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
All of the DURAMAX's as far as I know only have 1. 01-02's used an oil pressure sender mounted on the front drivers side of the block and measured oil pressure leaving the oil pump. 03+ have an oil pressure sensor mounted on the drivers side of the block about midways down it just in front of the oil cooler/filter adapter housing, and measures it after the cooler IIRC. This is why 01-02 trucks tend to show more oil pressure than 03+ trucks do. Also 01-02's used a 1 wire sender wired straight to the cluster, and the 03+ trucks used an actual 3 wire sensor wired to the ECM, and it sent the oil pressure signal out over the data bus.
Henry95
283
Thanks. The gm guys were really confusing me as I thought there was only one.
