Getting an allison to hold TQ
TwistedDiesel
Road Oiler
Nov 15, 2013
11
Linden TN
I have an Allison 2400 behind my 7.3 powerstroke that now has 400mm injectors and a 74mm VGT turbo. Now I'm playing tranny catch up!
I did the converter flow valve modification so I don't lose any line pressure during lockup now, and that helped a lot. I can no longer slip it while locked in gear, but if I let it shift under any good amount of power it shifts too slow and flares badly and if I'm really in the throttle it will the lose it altogether and the engine will go to redline and that's it. It just cant shift solidly enough under power. I can't do any sort of defuel with my engine so that's out of the question. What does the transgo jr kit really do? Does it make the kind of difference I'm looking for? Any other modifications I can do without sending it out to a really good builder that knows all the tricks? I've got a full machine shop here and am not new to the internals of an Allison, just never had to make one hand this kind of torque before.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,517
501
Central OH
So it's all stock currently besides the converter valve mod?
Contact Evan at Limitless Diesel, he'll hook you up with the parts. Or do some searching here and you'll piece together what you need
15,681
Why would you take it apart only to do the flow valve mod? You still don't have enough pressure and clutches.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Without defuel you're going to have to go full built to accomplish much, and then you might end up with broken shafts and such like was common place before tuners stopped turning defuel off completely. A clutch to clutch trans really needs defuel to shift nicely IMO. Without defuel your build will have to be stouter than equivalent power output DMAX, and your trans tuning will be critical to avoid tie ups. I understand defuel isn't an option for your ECM, but it's putting you at a disadvantage. Clutch selection may be a little tricky with the extra abuse yours will see on the shifts.
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,214
364
At Da Beach
This will be difficult bc Allison transmissions are inherently slow shifters. I'd have gone full built 47rfe or maybe a duraflite. Good luck and buy billet shafts if your pushing over 1000flbs of torque...
TwistedDiesel
Road Oiler
Nov 15, 2013
11
Linden TN
Thanks for all the great responses. Mike L I see you have options for 290 and 310 PSI, that doesn't stress the case lugs? I'm going to have to get with you for some PR and trim springs. I'm going to give you a call in about a week when have some more cash, so feel free to leave me a list here of what you recommend to save phone time. I come from the MD and HD side of Allison so forgive me for not having mu light duty shit together!
At some point in the future I will have SEM (shift energy managment) capable ECM but for now I need to get this working without it. I'll be running a DDEC IV 60 series Detroit ECM and it has J1939 and SEM messaging and I'm very familiar with tuning/hacking them.
I was looking at limitless diesels kits, they're pretty inexpensive, and from what I hear Evan really has these figured out. Will his kits have the correct selection of clutches to do what I need or since I'm talking to mike already should I just have you put a kit together for me?
I sure appreciate the help.
coker6365
Coker6303's ***** Daddy
Dec 4, 2011
486
The new Alto G4 clutches are looking very good so far.:happy2:
Are those still the same keyhole design as the G3? Curious how they do under a lot of power through the shifts.
Sent from my SM-G965U1 using Tapatalk
15,681
My prototypes are still key hole. Production design should have solid design.
