Gettin Pretty Frusterated
Nov 1, 2010
49
Lost Nation, IA
i cant get my stock torsion keys out they are rusted in good and tight. Ive tried an air hammer and sledge hammer and i still cant get them to budge. anyone got any suggestions? im scared to heat it because i donnt want to ruin a torsion bar
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
I had to unbolt the crossmember (actually dmaxfireman did) and beat the ever living crap out of it with a sledge with the truck as high as I could get it.
madmatt
Apr 12, 2009
1,595
"the mecca"
www.facebook.com
the last set i did i soaked for two nights with some PB, had a buddy hold one big ball peen while i smacked that one with a bigger sledge. Took about 4 smacks this way. Before i soaked and had help i beat for 2-3 hours with no luck.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
As others have said, soak the crap out of them and make sure they're completely unloaded obviously. Then get a sledge and go to town. Soak in ATF and acetone 50/50 mix, PB, Kroil, something of the sort.
-Shep-
RCLB kind of guy
May 4, 2011
75
Tennessee
Kroil is awsome stuff. Whatever you use, be sure to use it on the key AND where the t-bar slides into the control arm.
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
Here is another good product you gents should get and try.
http://www.laco.com/prod/49/rust-buster.aspx
I've used this stuff and nothing else has come close to getting rusty parts separated unless heat was involved. When I had to do ball joints on my Jeep the hub/spindles etc disassembly was a mother. After squirting the rust buster on the parts let it set for a few minutes and a couple hits with the hammer it came right apart.
