Hey all. This will be my first winter plowing with my LMM, had a couple questions I was hoping to poll you on. Plow is a Fisher XV 8'6". It weighs 900lbs. I usually use a company vehicle but since this will be my own I want to make sure she's well prepared. This isn't my first rodeo so I don't need plow lessons Truck has 70k miles.
1. Tune setting while plowing. Have DSP5 with a stock/light tow, heavy tow, DD/street and two higher race tunes. I was thinking stock tune. I am still on a stock transmission. with any luck and a few good storms I should have the coin for a build.
2. Truck is a CCSB, are frame gussets recommended? If so, where to look? Google doesn't turn up much but i'm sure i'm using the wrong wording.
3. I bought the truck leveled, and have acquired purple keys to lower back to stock. But this is a heavy plow, should I keep it leveled to allow for the extra weight? At minimum I would turn the stock keys up a bit but will not sacrifice CV angles for height so any adjustments will be minor.
I built the front end this spring using rare parts and other beefy stuff. New CV's, brakes/calipers and rear leafs are all being installed this month when I find some time. Fluids are well within intervals and I grease suspension/u-joints at appropriate intervals.
THanks all
THanks all
