Georend vs suncoast
Yngdmax92
962
Doing a truck up for a friend, going to be running a dp 68 stg2R.
Truck is equipped with a georend R right now, been told the 1078 is better suited for the turbo. Fuel is supersport pump, and 60 overs. Is there really that much of a difference before I go ahead and put this trans back in the truck?
Going to be used for a weekend warrior, occasional drags and 3-4 sled pulls a year. Is it worth the swap? Lmk and why. Just looking for the best overall set up.
KRODMAX/KS
It'll be alright
Jul 27, 2017
174
21
Oz
My truck was was laggy and run dirty down low with the R. Mike L said the K (Goerend) is what was needed for power level I was at. The "K" makes the truck way more responsive and a blast to drive. Check my sig...sorry, don't know a thing about the 1078, it may be similar?
Evan@InglewoodTrans
yerp
3,118
65
Western MA
I’d try the R and see how it does. I find the 78 flashes a little higher then R which helps get on top of the charger before the agressive fluid coupling both converters have comes in but I think the R will do fine.
Yngdmax92
962
Thanks fellas,
Just don't want the truck to blow through the converter, rather just blow the tires free. I'll report back for sure.
15,681
You won't blow through either one. They are both great. Question is the stall for your particular needs. Stall is for a launch and 50 feet out of the hole it's over. Coupling takes over and gets the power to the wheels.
Try this test.
Bring your truck up to 30/35 mph and hold it. Mash the throttle hard, but not enough to make a down shift. Watch the tach; it will jump 500rpm and at the same time watch the speedo. If the speedo lagged way behind the tach, that 500rpm jump just went out the tail pipe and never got to the wheels.
With a good coupling converter; this same test will have the speedo following right behind the tach, and that is getting the power to the wheels. That my friends is coupling.
1TRIKHD
Country boy Limo.
Sep 15, 2015
1,692
388
P.N.W
Try this test.
:thumb:
Yngdmax92
962
Try this test.
Thanks Mike! As soon as I get it back together and update the tune I'll report back.
Definitely understand what your saying about rpm out the tail pipe .... Big tune/stock converter. Almost like I put the truck in neutral and rev it up
prostreeter600
Street rodder
Jul 18, 2010
893
Dallas Tx
I can tell you from personal experience when it comes to service after the Sale you wanna go with Goerend . Dave is excellent to deal with , he is extremely fair and a good person .
ikeG
Oughta Know Better
Apr 19, 2011
2,462
146
Western PA
www.facebook.com
Exactly. Both make quality products and the 107x converters are supposed to be awesome, but it was hard for an average Joe like me to get ANY customer service out of Suncoast. Meanwhile the entire Goerend crew including Dave Goerend himself bend over backwards
Sent from my XT1585 using Tapatalk
5,783
Try this test.
you forgot to mention the donation of rubber to your city streets when said test is done and the damn thing couples! :roflmao:
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Can't get a 1078 from suncoast. The good part with evan is he knows what converter works on each specific set up. He has been around the diesel game long enough to know all set ups.
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
If Mike drives your truck and lays rubber while pitching the ass end sideways and it puts a huge shit eating grin on his face you know you got a good converter :thumb:
Woodster
Computer Nerd
Aug 28, 2009
176
Utah
Whatever direction you decide to go be sure to chime in and let us know. I'm in a similar situation. Just trying to decide on what to do.
Yngdmax92
962
Anybody have any reviews of the georend DK converter. Dave recommended this to me on the phone nefore I through up this post. He did t really give details of the difference between this and the R. maybe someone knows?
15,681
DK is very close to an R. There was a problem getting cores to make an R because it takes 2 converters to make one. Dave found a way to make a converter that was almost identical to an R. I have used them and they are great.
Slowmax
Build what others' won't
Aug 3, 2013
468
United States
Goerend is the only converter I'll ever install in any truck. They take care of you after the sale. Instead of just taking money out of your account, and sending you on your way.
