gaskets and studs
dmax711
Mar 4, 2011
1,057
concord, north carolina
How many of you guys have put grade c gaskets and ARP's in? What are you running for h.p and boost? Doing mine in the next few weeks and just seeing how hard you guys are pushing stock internals with the arp's in..
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
You will be good to 600-650hp until the rods bend depending on tuning. They can bend at less with poor tuning. I bent mine before the head gaskets even thought about blowing with stock head bolts.
PAT
EASY DAY
Aug 21, 2011
1,100
your back yard
I would just save the money man. Leave it stock for now. Get good tuning and run at 600 ish till it lets go. Then do it all at once.
Josh2002cc
That Uncle
Apr 2, 2007
1,832
I run the c's and bottom level ARP's but run a stock truck. I agree, don't bother if you plan on pushing it. No need to go in and take stuff apart and buy new gaskets when you will end up doing it again in no time at all. Of course, this all depends on how far you do push it. Good luck to you.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
I have C's and standard studs, been around 20k since the engine was rebuild no problems, boost runs around 50-55psi
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
I canr believe that guy that had the truck didnt do the arps with a full build and twins i know the stocks will hold a decent amount but while he was in there would hve been nice if he would have installed them........for you benifit :D
ARP's here and C's here
thneill
Whered all my $ go
Aug 23, 2011
144
East Texas
While were on the subject, my dad just ordered 75 horse injectors and a 42% over cp3 for his 03' lb7. Does he need arp's or will it hold without them?
blk smoke lb7
Nov 8, 2010
5,694
57
belvidere,ill
I wouldnt pull perfectly good and sealed heads untill they pop JMO,but knowing what your adding your probably gonna be a little hard on the head gaskets and the rods.
dmax711
Mar 4, 2011
1,057
That where i was at, and then they blew and i had to do them lol. I am planning on running it hard and twinning it. I know its not gonna last and a build is inevitable.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
As far as HP, my truck dyno'd 585/1000 before I bought it, and ive turned it up some since then, but I havent owned it long enough to tell if there are gasket issues.
So far so good... :thumb:
dmax711
Mar 4, 2011
1,057
IDK evan, hopefully its one of those freak lly motors that i can beat with a s480 and run 11's with. most likely not but we are def gonna see how much she can take:woott:
Evan@InglewoodTrans
yerp
3,118
65
Western MA
I'm sure we can get the old girl to dip into the 11's before she dies :hug: If I had known how well my motor was going to look inside when I took it apart it would of stayed in for another year.
dmax711
Mar 4, 2011
1,057
yeah that sounds like a plan:D im just gonna slowly build the block i got from ya, then if my stocker is still alive we are gonna make a few all out bonsai runs!:alc:
