Question: Garrett VVT Turbine Wheels
Dashman
Oct 11, 2009
Can someone help me with a distributor and/or a part number for a GT37, journal bearing, 77mm inducer, 78 trim, turbine wheel and shaft? Could be slightly under those sizes. From what I understand, it should be a wheel designed for variable vanes. You all should know exactly what I'm trying to build, so I don't want to hear, "just buy one". This wheel is the last item I need. Thanks for your "productive" responses! Have a good one!
Dashman
Oct 11, 2009
Right on, Mark!!! Now that's what I wanted to hear. :thumb: I have some sheet that came down recently, or I'd be on the phone tomorrow. :( I'll hit you up in the near future though. It'll be a pseudo GT4094. Something similar to what Danville has done. Just with separate and spaced out costs. By the time the journal bearings give out, I'll have a ball bearing CHRA ready to replace it. Everything for these Duramaxes is EXPENSIVE!!! I can't do most upgrades all at once. Also, it's a daily driver and can't be down for long.
