OK here is one I can't find an answer to. Riding around yesterday got out smelled fuel, looked under truck and major fuel leak coming around trans and oil pan. Cut truck off fuel stopped after a few seconds. I have an air dog, restarted the truck no fuel leak for a few seconds and then the gusher. I checked here and found to look in the valley of the engine because of where the fuel is running. The leak is in there some where but I don't know where. I have no codes, and the truck will run once started like normal. Doesn't like to start, long crank but once running runs fine. I am hoping that it is a return line busted on the cp3 but I can't see the thing. This thing is blowing 1 to 2 gallon a minute when the truck is running if it was my cp3 gone bad the truck wouldn't run I wouldn't think right?
BCBIO
BCBIO
