G-tech results
Lennart
Not from here !
Aug 10, 2006
305
Detmold, Germany
Well we finally had a cold but dry day in a long time and I managed to hook up my old g-tech while cruising around.
I did not go into 4WD so my launches were pretty bad....
I did only one 1/4 mile with [email protected] and a 0-60 of 6.45s.
These numbers are from a launch without any boost...single footed. I was also running on 100% SVO.
The speed somehow tells me there is a lot of potential left on the 1/4 time.
Thoughts, anyone?
Lennart
Not from here !
Aug 10, 2006
305
Detmold, Germany
Sorry but my old G-tech does not display 60' times...
I did another run 14.65@104mph and ran EFILive in parallel...which only showed a max speed of 99mph towards the end.
This performace I get with a 2800µs shot at 127-130MPa on SVO.
I really need to get a second CP3 to get more damn fuel into the motor!
JQmile
Jul 6, 2007
G-tech is about 4mph high as compared to dragstrip times cause they don't measure over the last 60ft but right at the end.....also make sure your road is super flat and you're zeroed perfectly at .00 when you start the test....ao actually you're about at 99-100mph....but nice times for 2wd!
