I have an 01 - lb7 Allison. I lost the TCM communication on a 400 mile drive home. Came home in limp mode. I have EFI Live V2 and a stand alone cable. was able to boot read the TCM with a stand alone harness. So off I went - replaced ignition wiring and rung everything out. put in original TCM -no communication.
Go back to stand alone - no communication.
By this time, I've picked up TCM controller #2 & #3. All TCM's are same model number / base number 29537441 - service number 15768288
All TCM housings identical but different manufacture dates 2000 thru 2001 - mine mid year 2001
So I put in TCM#3 - program my VIN into it - all functions come back but rough shifting - try to reflash #3 - says cannot reflash because of base operating program / bios not compatible.
So I put in #2 that has a manufacture date close to mine - VIN already programmed. - same problem on full TCM flash
Any thoughts?
Is there a way to do a complete reflash using EFILive V2 flashscan that I'm missing?
Or should i give up and take to a stealership?
TCM 2
Serial 1213M0020508
Hardware 693335105
Operating System 15175854
Calibration 15079906
BCC 9906
Transmission 15175857
TCM3
Serial 9363M0020508
Hardware 693335105
Operating System 15065810
Calibration 15065802
BCC 5802
Transmission 15065804
