cannt get the furnace to light.. uncle left the heat turned up while i was gone and ran the tank dry..
i just replace this http://www.grainger.com/Grainger/ALLANSON-Oil-Burner-Ignition-Transformer-23M552?Pid=search
motor runs, fuel is primed motor it wired in parallel with ignitor and controled by this http://www.grainger.com/Grainger/ww...ch&Ntt=4e291&N=0&GlobalSearch=true&sst=subset
i have check the flame sensor and have ~100ohm acrossed it when off. with the furnace on there is 40-50 mV across the poles.
the sensor is relatively cheap.. but i dont know what is good or bad..
http://www.grainger.com/Grainger/ww...ch&Ntt=2e523&N=0&GlobalSearch=true&sst=subset
anyone got any info that could help... grainger is closed till monday
