Question: Fuel valve
speedmetal6.6
Dodge Destroyer
Nov 3, 2008
252
Gillette,Wyoming
As most of you know I have been having some problems lately with getting An 0087 code and its been happening easier, I just get on it for a little bit and bang the check engine light comes on with the 0087 code.When it first happened I was racing a dodge and we got up to at least 120 and I then it came on when I let off. I went down a power level and it hasnt done it since. I was told to get a lift pump wich is in progress and I was also told to shim my fuel release valve. My question is I bought a race fuel valve from PPE and I was told that it is only for hot tunes like 350 and up or it will cause damage to my fuel rail and cp3 is this true or not I just bought because I thought it was better than shimming mine because it acts like it might be f@#ked any how let me know what I should do ( thanks):confused:
tinman22
715
Stillwater NJ
lift pump cured my p0087 codes on my 06 lbz. I didnt want to mess with the fuel rail because I heard it was a real bear to break loose and do the shim kit. as far as damage. someone else would have to chime on on that one
slowlmm
Mar 2, 2008
2,582
46
so cal
I would do the shim over the valve. basicly with the race valve in your rail canot relive presure so in theroy it could spike past 30,000 psi wich could cause a failure to the rail or damage the cp3 with the shims in you still have a working fprv and can still relive presure the shims just make it do it at a higher presure
speedmetal6.6
Dodge Destroyer
Nov 3, 2008
252
Gillette,Wyoming
One More Question
Do you think My valve is bad and could be causing the code to kick on easier because like I said before, the first time it happened it took alot to kick it on I mean that was the most I've ever gotton on the truck and now If I accelerate up the on ramp to get on the interstate it comes on . That leads me to believe I need something else before the lift pump but I dont know what.
