Just run an lbz FPR, shim the FPRV and do some nozzles in the 30%-40% range. On a stock motor that will never be built, I personally like 30% over nozzles. Can make plenty of power to cause much carnage, also won't stress the cp3 as much.
I put my full weight crew cab to a 12.3@110 with an lbz cp3 and 30% nozzles on a 2300us tune still holding 24.5k rail pressure. Have made 754hp on the dyno with dual pumps and a 2450us tune with my 30% overs. I will probably stick with my 30's for a bit after my engine is built, I'd expect probably an 11.4-11.5 in the quarter mile from my 30's on a 2950us tune in my crew cab.
If you plan on an engine build, I'd say atleast step up to 60% overs and dual pumps then tune accordingly.
