I've got a real rats nest going on with all the fuel returns on our pull truck. Would love to eliminate the factory blocks and run neat lines. Looking for any suggestions, and pictures would be awesome. Even if your setup doesnt work for me, pictures will get my brain storming. I know this has been discussed at random before, but with all the late engine builds goin on, i figured it would be a good idea to start a new thread.
FICM is run dry. Do not use the fuel temp sensor. So there's at least two of those nasty OEM hard fuel blocks that i could eliminate. Problem that i see is how in the wide world of sports do you convert each inj return line to anything else?? So we've got 2 injector return lines, both pumps have a return, and then there is the PRV. Someone correct me, but can i just leave that PRV fuel line dumped by itself? Assuming it never pops? Thanks.
