OK a friend of mine has fuel in the oil, I checked the balance rates all is well, so I guess it's a fuel return line leaking, is there a way u can determine which side is leaking? This just started happening tonite with no worring, also the engine has a miss in it, but the injectors check out good, so I do a compression test. I'm lost on this. No work has been done to the engine stock 02 LB7.. Any help would be appreciated...
