Fuel Rail
wdino73
735
55
Versailles, Ky
How does the fuel rail work, I know that fuel enters it an feeds the injectors, but on the left side, how does it feed the injectors an flow enough thru to the rt side, is there 2 chambers in the left an if so is it possible to clogg it up ( Like when changing the cp3 getting debris in the line. ) so it won't fuel the left side injectors while the right side fuels correctly, I'm just trying to understand how these work to maybe rule out this possible issue. I've not seen this ?? asked it my be a stupid one, but I'm curious.
Thanks,
Dean
wdino73
735
55
Versailles, Ky
Sorry guys I wrote that early this morning an was half asleep, the fuel goes into the fuel block then from thier it goes to the left an right rails, is it possible to get a fuel rail clogged, I think that their is an orifice in the ends after the fittings?
2500HeavyDuty
Book 'em, Danno!
Feb 14, 2008
2,209
Katy, Tx
www.myspace.com
where the fuel line goes into the rail behind the fuel rail fitting there is a little itty bitty orifice behind it, it could get clogged, buts not hard to clean out, i drilled mine out to .125
there is some corrosion that does build up and if its not clean up when you take it apart it could get in the fuel system
wdino73
735
55
Versailles, Ky
cool, the reason I'm asking my problem started when I had to pull my cp3 pump, then the truck ran bad, I had good fuel rail pressure an no codes,, I did find a y-bridge leak an the compressor wheel has some build up around it, I use the K&N filters which are wet, Now the trucks just not fueling right, I was just thinking that I may have an orifice clogged, I guess I'll pull the fitting an check them, Should I pull the rails an do a full clean on them, I guess it wouldn't hurt huh
6,123
this isnt much help dean but id jsut like to commend you on not givin up on your truck yet. you got some heart there man. if i were closer id lend a hand to ya all i could. If i can help you in any way ill try but i figured you would like to hear a little upper concidering all you have gone through so far :D
wdino73
735
55
Versailles, Ky
Hey I really appreciate your kind words, I'm a fighter have been all my life. I don't like to quit but God knows I've wanted too. I'll get it an maybe in finding my trouble I can help someone else in the future, That's what these sites are for,
Thanks Again It Means More Than You Know. :):):):):):):)
6,123
any time man. bein a mechanic myself i know how it can be sometimes and sometime the little things people say can really make workin on the truck that much better.
Happy wrenching in all seriousness!!! :hug:
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Just a thought but could you have oiled your mass air sensor?
wdino73
735
55
Versailles, Ky
Yeah, I've cleaned my maf, an changed it out, thanks for the help, I;m going to check my fuel rails later tonight, I've got the new head for this other truck I've been working on neeed to spend time with it. I'll post what I find. Thanks Again
simplepete
Jul 26, 2010
I am curious on what you found with your rail issues. I have an 04 LLY and I got a bad batch of fuel recently. Since then it seems like the DS bank is not getting enough fuel. I have a snap on scanner and when I turn off the odd injectors I see little to no change compared to the even ones.
