Fuel rail shims vs machined plug
John13296
Sep 1, 2015
So I've decided that befor I use anything more than a +90 tune I need to do something about the fuel rail pressure release valve, so my question is, what are the pros and cons of getting a machined plug, vs using the shim kit?
Robby05
Jul 25, 2014
498
Spokane, WA
I did a race plug, didn't want to mess with it again just in case I jacked up the shim install. Either way it's kinda a pain to do. Not horrible but plan on bloody knuckles. The bolts for the glow plug module bracket are tricky to get to & the valve is usually really tight in the rail. A 3/8 impact will fit in there to bust it loose if you have one
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,492
472
Central OH
The shim kit will still let pressure off under extreme conditions. A plug will not.
I run / recommend shims. Bosch put that valve there for a reason.
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
This!
Get the plug. I've had a shim still bleed off on me before. Plug you won't have to worry about that.
You might just need to shim the spring with another wahser, how many did you use? I used two on mine IIRC and have had no issues in 4 years and 50k tuned miles
quinton
1,883
Granbury Tx.
This!
I don't remember. Whatever came with the little kit. It really doesn't matter which one you go with, they both work fine. This is the only issue I've ever had with a shim. Never any issue with the plug or have ever heard of a issue with one. The plug just reassures me that I won't have to ever worry about it bleeding off.
Hot COCOAL
Jun 9, 2012
4,433
IIRC the kit comes with 4 little washers, using all 4 is the equivalent of installing a race valve/plug...I wanna say I only used two, but maybe I used 3, Knowing me, I probably used 3
Its a finicky little job, to take apart, shim and reassemble the FRPR valve...easy enough to accomplish but easy enough to screw up too...
quinton
1,883
Granbury Tx.
Ya I don't remember it was years ago. Ever since I've just done plugs. Easier to do. Unscrew stock and screw in plug. Done deal. Lol.
duramaxdiesel
Dmax Nut
Oct 23, 2008
1,378
47
Montreal, Canada
I have 4 LB7's and one LMM. LB7's don't seem to have this issue so this is new ground for me. I'm on the fence right now about what way to go too. Hopefully more people chime in. But, as of now I'm leaning toward shims.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Shims for me... Heard of some plugs leaking from being machined incorrectly.
A lot of the shimmed plugs will leak also but they will send the fuel into the return line so you can't tell. Once you break the seal of the factory plug its harder to get it to seal since its a machined surface seal.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
I have had a shimmed valve for ever. Never had any issues with it but watching my rail pressure up top, it has a little bounce to it when at 26,000+ psi. I wonder if the valve is bleeding pressure off.
My buddy with the same pumps and injectors had a race plug, watching his rail pressure, it was steady. Both same tuners, 120% injectors, dual 85% pumps on a 2700us tune. Maybe I'll install a race plug and compare.
N2BRK
2,054
371
I used to think shim for safety, so I shimmed mine in '08. But the race plug isn't blowing up trucks... and I am always wondering about mine being lazy these days. So IMHO I would run the race plug. I plan on swapping to it soon myself.
5,818
for the cost of a couple of washers from the hardware store, id rather try that first but its all personal preference.
a quick/simple bottle test will tell you.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Actually now that you say that, I am positive the valve isn't leaking. Because I've never had a hose hooked up to the nipple on the relief valve block and it's never dripped or leaked fuel. Totally forgot about that.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
If your a meathead and don't use soft jaws in the vice, then yes you could mess up the sealing surface. Nothing is idiot proof...
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,492
472
Central OH
I don't see how a shimmed fprv would leak unless you scored the internals during the process.
I only used 2 shims on mine, and it popped once before I shimmed it. I've gotten away with 1 shim on a LBZ fprv that hadn't been popped before.
John13296
Sep 1, 2015
Thanks for all the replies guys. Looking at it I'll go with the shims, and if I find a way to screw that up I'll definitely be investing in a plug. Also,stupid question, do I need to bleed the fuel system after I reinstall?
