Alright, so recently installed a airdog II 4g 165 pump and new 45% sac injectors. When the job was done, the truck is commanding 5k at idle but actual is around 10k...then sometimes would creep down to 5k, sometimes it wouldn't and just stay high. My mechanic thought the lift pump was putting out too much pressure so hooking his guage up pegged his 10psi guage. Unhooking the lift pump and the high rail pressure would come right back down. So put on a whole new filter base and regulator from air dog that they supplied to help our problem and the truck still has a problem with actual rail pressure being at 10k at idle. I don't have a pressure guage to check the pressure but could it be my fpr is going bad not able to withstand a lift pump? The truck does not lope at idle or anything weird that way. Or does having sac injectors affect my fuel pressure regulator somehow?
