fuel presure gauge ?
brown bear
como estan beeches!!
Mar 31, 2009
199
Durango CO
how can i install this gauge in my lb7 i think it come with this thing its call Sender column and i have no idea where it goes anything will help thank you pic would be pretty sweet to !;)
SIK LMM
Diesel Retard
Nov 26, 2008
176
CEN CAL
This is how I did my.
Whitetail Addict
Rockin' the stock tune
May 8, 2008
2,350
South Central Pennsylvania
Thats the filter housing (looks like its in the bleeder screw location?)...if installed in that position I should let you know of any restriction in the filter, if you retain the factory filter.
Also I believe the FASS system has a port to install a FP gauge.
brown bear
Mar 31, 2009
199
Durango CO
so whitch one its could be a better presssure to get the one from the cp3 or form rail pressure sorry i just trying to figure this out
brown bear
Mar 31, 2009
199
Durango CO
Also I believe the FASS system has a port to install a FP gauge.[/QUOTE]
huh ill check that out it may be a better options! thank you guys
Whitetail Addict
May 8, 2008
2,350
Both...haha! We have to have as many gauges as possible.
I have logged RP via EFI...no lift pump here, so no FP (vacuum). I don't run a big enough tune to drain the rail...so no worries.
A RP gauge is usually 30,000psi where most FP gauges are 30psi, to give you an idea of what you will be monitoring.
brown bear
Mar 31, 2009
199
Durango CO
alright thank you well see how it goes
brown bear
Mar 31, 2009
199
Durango CO
how to do the wiring
does any body know how to wire this fuel pressure gauge?
all i got done is the wires for the light anything im sure will help thanks
13,696
747
This is purely a guess based off the S and I stamped into the back of the gauge. I would suggest you call the gauge manufacturer or search online for installation instructions.
attachment.php
