If I remove the schraeder valve from the test port, anyone know what thread the fitting on the tube is? I'd like to put a fuel pressure gauge on there so I can see lift pump pressure, but want to be sure that I can get the correct sender or adapter.
That's only true for LB7s.That test port is just attached to the end of a rubber hose with a little clamp.
