Fuel Pedal no response
ICULKN
And Yes I drive it !!
Jan 6, 2010
158
SO CAL / New York
Had a strange thing happen about 2 weeks ago. Started the truck let it warm up for about 5 min. Went to pull out of the driveway, put in Drive but no Fuel pedal nothing happening stepped on it a few times but no Go, only Idle. Well I shut the truck off waited a few minutes and started the truck and it now worked.
Well today it did the same thing. But it took 2 times of me starting and turn off before I had a pedal that started to working. I know it is a Fly by wire. No Check engine light. I have to wait till I can check if any codes. Only programer I have is the Edge w/ Att. I have a 2004 lb7. Any one have a Idea ?.
darkness
1,317
380
vegas
you should be able to check throttle position on the attitude. see if it ramps up when youre having the problem. could be a bad pedal?
ICULKN
Jan 6, 2010
158
SO CAL / New York
I have never had a problem with the EDGE. back in 04-05 I had a few, but I sent it back and since then all has been good. Today no problems, Truck starts up and have a good Fuel Pedal. When the Pedal was acting up every thing else worked fine. Any chance it being the Computer for the in Cab stuff ??. Or would the Fuel Pedal be part of the engine computer ?.
Darius6t9
I'm the Floater. Lurking.
Aug 23, 2008
574
Rusk, Tx. Again
I have this problem also. Usually I pull over and shut it down. Get the codes. Clear the codes. And all is good till it happens again. Does it randomly. Next time it happens, I will get the codes and post them. But you might want to check all your grounds. That would be a good start.
