LB7: Fuel line spring clip
wsmithduramax
<--- Home Made!
May 4, 2009
474
Windsor, CO
Ok, I messed up the retainer spring clip that is inside the fuel line up by the diver side valve cover where the fuel line hooks to the pipe in the motor. So does anyone know if I can get that spring clip separate or can I just cut the end of the hose off and use some Fuel line with some hose clamps:confused:
Here's the pics of what I'm after
Thanks:thumb:
ikeG
Oughta Know Better
Apr 19, 2011
2,472
152
Western PA
www.facebook.com
You are apparently talking about the return line. I would just use fuel hose and a clamp. The hard return line should have that barb or shoulder for that quick disconnect fitting you have in your hand.
