Help: Fuel leak. HELP!!!!
Rosscup
Jul 2, 2009
46
So I just recently put 20% over nozzles and an s300 in my lb7. Everything was good ran great decided to put my old PPE on it before I got EFI just to see what it did. Ran good but then started leaking fuel in the crank case. Opened it back up and the #1 return line banjo seal looked like it got hit by the valve spring, the injector wasn't damaged the return line sealing surface had a ding in it though so I took it to work and machined it flat again (only too 5thou off of it) put the truck all back together with new seals and all drove it yesterday and It started leaking fuel again, not sure if ita the return line again yet because I haven't torn it back down yet all my balance rates seem good. If you guys have any ideas at all please let me know.
Thanks
Chris
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Did you buy these injectors new or did you just put new tips on your current injectors? If you pull the valve covers and hook your lines all back up you can pressurize the fuel system to see where it is leaking. Are you sure that the ding for the return line seal wasnt there or happened during disassembly?
JRODS*LB7
Feb 1, 2012
642
SE Massachusetts
Thanks
Chris
did you check both sides or just one side?also what i did to find my leak was pump air into the return line were you diconnected with the fuel line tool,near the fire wall.I found the leak instantly with both valve covers off!:thumb:
Rosscup
Jul 2, 2009
46
I only found the obvious leak on #1 and yeah I'm damn sure that wasnt from disasembaly, so you think I should pull both covers and put air to the system? Yes my injectors and new tips.
JRODS*LB7
Feb 1, 2012
642
SE Massachusetts
i would for sure doesnt hurt to double check even if you just pull the tops off like i did then when i saw the leak i went ahead and disasembled the other half
:D
JRODS*LB7
Feb 1, 2012
642
SE Massachusetts
K I'll tear it all back down tomorrow after work and see what I find
i just tore out my trans today to send to dipper and tommorow i got to tear my driver side valvecover because i think my #6 injector loosened up somehow?:thumb:GOOD LUCK BY THE WAY MAN! HOPE YOU SOLVE THAT PROB.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Yes that's an easy and definitive way to rule stuff out. That way you can tear into it once and be done with it.
Rosscup
Jul 2, 2009
46
No seeing any visible leaks with air. Any idea of anything I could put on the connections to see if it leaks?
13,752
822
Put on the injector lines and crank the truck without the valve covers. It may not be a return line leaking.
Rosscup
Jul 2, 2009
46
I'll give that a try tomorrow after work I'll need another person, thanks for all the help I hope I can get this figured out
slipclutchms
427
I think Ben had a thread about using a mitey vac and an old return line fitting to build a tester.....it would be easier to spot a problem if you pull a vacuume in it....
Dylan
Rosscup
Jul 2, 2009
46
Found my problem, passenger side return line going into the head was leaking, thanks for all the help guys! Time to get this thing tuned!
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Glad we could help. Did you pressurize the system as described? Pretty tell tale to find leaks that way..
Rosscup
Jul 2, 2009
46
Yup did it all like you guys said, I'm doin that every time I do injectors now! Thanks again!!
