after i installed my modded lbz cp3 pump and my mpi twins, now my motor sounds like a dang massey fergusen tractor. all balance rates are within spec, i keep a constant check on the oil level, there is no fuel in it. it gets louder when you put the truck in gear, and we were usiong a screwdriver to try and pin point the noisy area and the fuel rails are really loud. the passenger side one is noticably louder the the drivers. it runs good, smooth, what do you guys think could be the problem? injectors going bad?
