LLY: Fuel knock, need help diagnosing!
chandlergibson
chandler04
Jan 27, 2019
Pikeville, Ky
I have a 04.5 lly with 154,000 miles. a couple months ago I started noticing a pecking/knocking sound while accelerating. it doesn't do it all of the time, seems like it starts at about 1700 rpm and continues until the truck shifts gears and rpms drop. once I'm at cruising speed it stops, or I can't hear it anymore. would this be the cp3? or could it be injectors? I have no idea, but I figured this would be a good place to look to see if anyone else has encountered this problem.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Ice pick as suggested above, ck 2 and 7 injector harness, ck harness for rub through on the top of the ficm mounting bracket. Gm has update harness pig tails and plugs for 2 and 7 as they were routed a little to tight from the factory.
Ck that stuff first.
Bones775
Nov 10, 2012
9
Reno, Nevada
Grab a pair of these and cut n splice #2 and #7 injector wires
