LB7: Fuel in the oil after new injectors
02greysixer
1,829
North Central FL
Who's injectors? Only thing you can do is pull valve covers, run the truck and ramp up rail pressure to see if it is a return line or cracked injector
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
I did one where I left a return bolt loose :( driver side.. Pulled passenger side first and didn't find it..
On the plus side the oil was clean ;)
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
New GM injectors, from SoCal diesel. Got a few different issues going on right now, all fuel related.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Check return lines sadly :( see where that takes you.. Or make sure the feed lines are tight. Would cause hard/ no start though I would think.
The one I goofed on ran perfect until it started blowing diesel out the Pcv.. Only took about 5 minutes of running too...
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
Humm okay. Well I've got about 5,000 miles since injectors, and only a very very small amount of diesel fuel in the oil. I have a very small leak I guess.
